Broken Oil Pump?
operdot
USA
I'm doing a front 60k and after cleaning the oil pump area I found a small hole. I'm wondering if this is suppose to be here or is it a crack (start).
OilPump1aOilPump2OilPump3
operdot
USA
I'm not too familiar with the oil pump design. One of the questions I have is whether there are any high pressure oil passages near/behind that hole.
jimtash
nc
I don't think so and it would be leaking by now if there were. If you want to be safe though, fill it.
93rev2sev
Hockeytown
Mask well before using:
iTKL78xxdn14VjpEzxFOSreaWVtmCBHaSeyZB7iLMSuMnJa68_w-KTBcVKKmcL3pbgbudLXxtIEoppog0K8UH77mTTyMyACJz02bCy7f89OxaD7lAlcfk9CgOEaOKlkksJbfzGc0y2z65w4XokIx0Bw4rT7meG0rtgZ_6O3KOhQncDgqkxr9bff7xjDI3GRP4HQ5guY__wjKTd1GXofKVqFn0ZeLGGTDZPWxX9pMmPJn5-xXgWkzeouIuaocM-ll045fMQtoTruxgiO9Of-VOz8aSH6tmRarsM0Uk6WRXZUOCBz2uNTJZA-yCPteEQ
operdot
USA
I'm being a little cautious because I found evidence of a crank timing pulley vane hitting and destroying the CPS. Furthermore I found an incompetent repair that caused fretting in the the woodruff key/timing pulley contact area.
bmytych
