Danz13
ATX Sho Member
So I am replacing the bulbs in the foglight switch with leds, but when I reassemble the switch it only works on the first press then after that it seems like it gets stuck, so I pull the button part out and the white part was stuck up near where the bulbs are. When I take the button out it goes back down and it works again only for the first press. Maybe I lost a part or something when I took it out, I have the button, the white part, the spring and flat pin-length piece of plastic that I assume goes in the spring (it all fell out when I took it apart)
