Big problem- Male oil filter nub missing from block
waffles
Minnesota
Well hello ladies and gentlemen I have a problem on my hands. I'm balls deep into this rebuild and I realized that the male threads on the block for the oil filter are missing! If someone could find a way for me to get one I would love it! I would hate to have to stop this rebuild due to one stupid little part! :fit: Thanks guys!
TimboSHO
Intermediate
Wyoming, MI
Swap the one from your current engine when you do the swap. It's the same part from a 3.0 to a 3.2.
there is no male part. what you need is the tube that retains the oil cooler.
btw, if you are going to do an external cooler and want to put a remote filter adapter on there, the threads in the block are M20-1.5
waffles
Minnesota
PM'd Mr.Span. And I'm not quite sure what you mean? I think I'm missing a little metal threaded tube that I screw the filter onto? (the block)
Irish Pride
Irish Inside
MusicCityUSA
Is your oil cooler still there? you might need that too if the bolt is missing.
waffles
Minnesota
Not sure, what does this oil cooler look like? I apologize for my noobness, but this is my first rebuild.:thankyou:
waffles
Minnesota
0501132122_zps75fdcaee.jpg.html
Alright boys here she is
http://s1346.photobucket.com/user/tuckergrimley/media/0501132122_zps75fdcaee.jpg.html
Irish Pride
Irish Inside
MusicCityUSA
This is what it looks like, but it shouldnt be this warped. This was the one i just replaced. The bolt you are referring to that you attach the oil filter on is used to attach the oil cooler to the block. The bolt is threaded on both ends. One end goes thru the cooler and into the block and the other is left exposed so that you can attach the filter.
IMGP3792aA 28 zpsb6cdefe3
IMGP3787aA 28 zpsa845e694
waffles
Minnesota
What happened to your old one?
The bolt doesn't wear out, the cooler can - but that appears to be few and far between.
Doug
It just isn't there. This is an extra engine I got with the can that I am rebuilding and it's just not there.
