Bad leak (don’t know where it’s coming from)
James.609
I may very well be jumping the gun, but I cant see that being engine oil, transmission, or coolant. That's usually what ptu oil looks like it has a lot of aluminum in it from my expirience. I very well could be wrong.
No you were definitely right, I’m going to purchase a new PTU. Any suggestions where I should purchase one?
You get a good number of fails from some of those quick change **** places. That's not to say they messed it up for sure but I try and stay away from them.
If you need a new PTU
https://www.tascaparts.com/oem-part...w1wkd2djiF-X-yfBgrvRemvdRRazVZPhoCcXIQAvD_BwE
Part number if you want to shop around- at4z-7251-g
Alot of times I would go used. This part I would be hesitant. Good luck and post back.
Make sure 100% this is the failed part before you pull the trigger on an expensive part.
James.609
Went to meineke for a diagnostic, they said it was the issue. I’m going purchase one from the ford dealership just so I have the warranty.
fordfanstan
CA
Are you experiencing any drivability issues at all? So far I just read that you have a leak, it appears to be gear oil from PTU, directly after going to a shitbox **** shop. Are you for sure it just wasn't over-filled or something similar? Where is the leak coming from.. the vent up top or? I would just try to find more out before shelling out for a new PTU. Best of luck.
James.609
I decided to replace the PTU with a new one, I won’t have to worry about it later.
You will if you keep it long enough.
I would suggest you get comfortable enough to do some of this stuff yourself and/or find a reliable good mechanic to keep up with this stuff. Even dealer service is hit and miss. Those national chain oil and muffler places are much worse. I have a guy at the speedy chain shop I would trust with anything in my old SHO and f150. but everyone else there, no way. And having used a bunch in other chain shops in that area.. nope.
James.609
that’s true, I learned my lesson. This is off topic but is possible to install the L E D conversion kit on a 2010 sho ? I can’t find anything about it
Dirty Harry
Orlando, FL
I would just clean up the area and keep driving it. Check it out first. It may have just been overfilled. Judging from the service ticket, they either put you on the spending elevator or you don't mind throwing money at your car. After getting screwed up at Valvoline, why go to a muffler shop to get your PTU checked?
PTU gear oil is far from odorless, but it does smell way better when brand new. Old fluid smells like ... well you won't be getting that stink off your clothes any time soon. Have someone else "smell test" it.
stripSHO
Idiot Savant
Detroit
I'll 3rd the motion that potentially it was just overfilled. This past fall, my stepfather had his trans flushed on his f250 the week before a trip to the U.P. The truck ran flawlessly for 400+ miles. But once we hooked our 24' pontoon to the back she was belching transmission fluid pretty bad from the vent within 30 minutes. Never got low on fluid, never had a drivability problem for the 300 mile haul home or in the 5 months that have passed since, and has never leaked since.
stripSHO
Idiot Savant
Detroit
So I finally got around to doing my first oil change on my ‘16 PP (3k miles since I bought it, 45k total). I too had a fair bit of gear oil along my PTU. Only in my case the oil looked and felt brand new so I highly doubt an actual leak. I’m hoping the dealership I bought it from went above and beyond and actually changed the PTU fluid, leaving a little mess behind. Or the other possibility might be that it’s actually brake fluid and my ******* can’t tell the difference, but I don’t know if there’s even any brake lines in the vicinity that could be a source. It was very thick and a little tacky. I’m open to any interpretation or suggestions from those more in the know on PTU problems! Sorry the pictures suck but you know how it goes crawling around under a car in the dark
6C42D27B BF8D 41EC 9192 6B124914158E 6EDFE371 7EC5 4BBF BB2A 82C8A9B3D220
Kevin81
USA
View attachment 13990 View attachment 13991
There is no mistaking brake fluid for gear oil. Brake is very thin, has a unique feel when rubbed between your fingers, and will wreck your skin. Gear oil smells, is thick, usually black, and is impossible to wash off completely.
stripSHO
Idiot Savant
Detroit
Thank you. I thought so but it’s been so long since I’ve even looked at a bottle of brake fluid that I was doubting myself. So yeah it’s definitely gear oil but I think it looks too pristine to have previously resided in my PTU. Just going to wipe it off and keep an eye on it for now I suppose
shootinirons
