Backfiring, poor running
autobahnsho
SHO Victim
NY for now, WY for real
AAAARRRGGHH!
So around a month or so ago, I got the seals to keep my spark plugs from deep-sea swimming in oil. (The oil was to the top of the wells.) Do the job, and the car started running poorly.
5 plug wires were cracked- 2 so bad you could see large amounts of metal. I was guessing that the oil was insulating them so they weren't arcing, and when I pulled the oil they started to arc.
Tonight I spent the precious 2 hours I had pulling the intake off, putting new wires on, and re-assembling. It starts up great, except it was backfiring big time.
I double-checked HERE to make sure I got the wire order right, (and you'd have to wonder why #5 wire is so short, anyways.)
Someone suggested a vacuum leak, so I unbolted and re-tightened the manifold bolts. Still backfires, and feels like it's running on part power.
Obviously when I get more time I'll spray around to see where/if it's leaking, and pull the codes tomorrow. Any other ideas?
Thanks,
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
You're positive you got everything reconnected? PCV lines, Vac line at the rear of the manifold, ground wire, crossover tube bolts, and finally, plug wire order? I find it very very strange indeed.
Mr Anonymous
Tire Wall
Backfiring is either caused by misrouted plug wires, or by a timing problem.
Do your wires match this photo?
DHMag
Free At Last
InCahoots, Texas
attach the ground strap back onto the rear tank ? what about tightening the 2 bolts on the crossover tube ?
autobahnsho
SHO Victim
Thanks for the responses-
I double-checked all my connections, the groundstrap, and all my bolts.
Yes, when I got home I found the wiring picture above in another post and double-checked outside. I might have 4&6 switched, but I will check after work. (Ruck-marching and Gas mask training outside in the snow all day today- Yay. :rolleyes: )
I guess I'll just have to print the picture so I don't brain-fart and forget the right order when I get outside.... headbang
ps- Does the rear (acc. to picture above) passenger side stud that the groundstrap goes on strip out easy?
When I was putting it back together last night I tightened it into the intake, then put the strap and nut on. I tightened that and it spun the stud in place. I hope I didn't strip it (or the intake!)
autobahnsho
SHO Victim
Well, congratulations!! Problems fixed. :D
I knew that wire #5 was funky, but I had mixed up 4 and 6. madflame
Right after work I looked at the drawing again and fixed it.
Sure glad I didn't have any OTHER major problems.
Now time to save up some freetime and a few $$ to tackle rod bearings...
And thanks for your replies. I would have been scratching my head till there was nothing left, figuring I had major issues. To my fellow SHO-ers:
hail
thumb
