backfire + no start
shoff89
upper marlboro,md
As soon as car is turned over it sends a yoga flame through the intake and wont start. just keeps crankin. after getting out and looking under hood I hear a hissing sound dont know exactly where its coming from . any suggestions?
kurtis adum
Driver
michigan
i would check out the wires, i had the wires hooked up wrong gave me same kinda thing. i know in one of the manuals it gives the wrongs ones, do a search and double check it
kurt
projectSHO89
SHOless In St L
If it is still backfiring, then one of the following HAS to be the problem:
Plug wires misrouted
Valve timing fault
Valve stuck open
Steve
shoff89
upper marlboro,md
well. I got the thing started today, i pressed the gas to the floor and she strted after about 20 seconds of crank. drove it around it still wouldnt hold idle. next time it died and wouldnt start unless I tapped the pedal a million times. Now Im realy lost as to what is wrong any sugg? oh and its still backfiring and popping at low rpm and has no power.
Mike Kopstain
Arlington Heights, IL
Has any work been performed on the car recently? It sounds as if the timing belt was put on incorrectly or if the car hasn't been worked on recently it sounds as if the timing belt jumped a couple teeth. Either is going to require a new timing belt.
We had a car snap a cam but our case was the only I have ever heard of so I wouldn't say that's a likely problem.
Also, when checking spark plug wire order keep in mind that Chiltons and Haynes both list the coil pack as being (from top to bottom) 6,5,4 when it is actually 5,6,4.
As Steve said backfiring through the intake is a timing issue or mechanical valve problems (highly unlikely on the latter).
