auto trans problem help!!!!!!!!
funkyputz
floyds knobs, in
i have a 93' sho atx. trns will not go into overdrive. the rpms drop and acts like in nuetral till i give it gas and drops into 3rd.
please help thanks.
Bluto
Rochester, NY
It sounds much like the tranny is slipping very bad.
How is the take off?
Does it feel like the car is slow up to 25mph?
ShoGuy93
Yes I Have Blue Rims
New Palestine, Indiana
Has your vss been replaced??? It may be that?? O and where at in Indiana are u located?? Or what major city... I may be able to help out...
<small>[ May 26, 2003, 09:02 PM: Message edited by: ShoGuy93 ]</small>
rangerj
Brunswick, Ohio
funkyputz,
Test the torque converter lock-up solenoid. It causes the torque converter to lock-up and act like a fourth gear or overdrive. Check the connection for a good electrical contact first.
If the solenoid (or sometimes referred to as a "servo")is OK, then check the VSS. rangerj
