Denny
Taurus Homeland
I can't get it figured out and I've had the help of a couple of SHO guys back at home. Same story, I'll still stall if I touch the gas aggressively right off of idle. Have a new fuel filter, air filter, plugs and wires with new plug well seals. Fuel pressure was ok. Swapped out TPS and MAF, put in new IAC and had the 60K done this past Saturday (however we didn't touch the timing belt) I'm running out of ideas? Only codes I get in the Key On Engine Off are 24 for "Air charge temperature (ACT) sensor out of self-test range." Could that be it? Would that really **** the engine after idle?
