anyone put strobes in the fish tanks?
TheKrazyRaven
4 8 15 16 23 42
Lawrence Massachusetts
AutobahnSHO1130:
TheKrazyRaven:
AutobahnSHO1130:
yea if you wanna run relays from the rear to the front of your car, easier just to run 2 different sets and deal with the left right action..
Not sure how the X pattern would be wired, but it would cause ALOT of wiring to be done
i know it can be done easily, my father used to build police cars when i was younger
but i dont speek to him anymore, so i cant ask him
Federal Signal Wigwags are on ebay from time to time for about $30..IIRC
i can get them for free out of an old police car thumb
James Downing
Virginia Tech, VA
hey, AutobahnSHO1130, just outa curiosity, and off topic, in your sig pic, it appears your lower grill doesnt have the middle bar... looks like one big opening... mine has a cross-bar in there... did you remove it yourself? i like the look.
i guess its not really noticable on the green ones, but looks good with white...
<small>[ November 13, 2003, 10:46 PM: Message edited by: James Downing ]</small>
Chris Benvie
Every so often
RedSox Nation
James Downing:
Its actually a Photoshop but in the process of becoming a reality, yes I am having it removed, better cooling and looks better. Doing a lil other trick too :)
RStalveyARFF
too many shos
Georgetown, MA
go with the strobes. The wigwags on xenon headlamps will cause the bulbs to blow quickly. I'd go with either the SHO-ME setup being sold on ebay (6 strobe power supply with 4 hideaway strobes) or get galls hideaways and a galls PS.
Chris Benvie
Every so often
RedSox Nation
James Downing:
OOOH, whats the 'other trick'?? that picture did look good, how are you planning on doing it? just some good ol body puddy?
It can be cut out and shaved, replace a few pieces with ABS plastic, little bit of apoxy and wallah, better cooling and a new look
The trick.. its done alot with the Gen3 SHO's paul nimz car has that front skirt of black ABS plastic. I will be doing the same..
The 95 SHO's and some of the other Gen2's have a splitter on the very bottom of the bumper Using the black Plastic I will basically replicate it, only about another inch lower and it will be integrated (melted persay) into the bumoer and re sprayed.
I was also looking into doing something a lil bit like the POPO girlle for the Gen2, working on a photochop of it, to see if i like it.. I like to be different :D
