vforrest
So when my adaptive cruise is on and someone jumps in front of me and my car auto brakes...does anyone know if my brake lights are also coming on to warn the car behind me?
the adaptive cruise does not hit the brakes, it only has the ability to reduce the throttle.
Here's what the 2011 factory service manual lists as the description for the adaptive cruise control:
Cruise Control — Adaptive
The adaptive cruise control system consists of the following components:
Cruise-Control Module (C-CM) (located behind the left side front bumper cover)
Adaptive cruise control indicator (located in the Instrument Panel Cluster (IPC))
Cruise control switches
Cruise control deactivator switch (part of the stoplamp switch)
Stoplamp switch
Cruise control indicator
PCM
ABS module
Electronically-controlled throttle body
Clockspring
Radar sensor unit (part of the C-CM )
Head Up Display (HUD) module
The adaptive cruise control system operation is similar to the standard cruise control system. The adaptive cruise control system is comprised of the PCM, the ABS module, the C-CM , and inputs from the brake pedal switch and the steering wheel switches. The adaptive cruise control system is controlled by the steering wheel mounted switches ( <--->, ON, OFF, SET+, SET- and RESUME). The <---> symbol on the cruise control switch is the distance gap switch. The adaptive cruise control system maintains a road speed selected by the driver from the steering wheel switches and that speed is displayed in the message center.
The vehicle maintains the selected speed until another slower vehicle is detected ahead in the same lane by the radar sensor unit. The vehicle speed is adjusted automatically to maintain a preset distance gap. When the adaptive cruise control feature is activated, an amber adaptive cruise control indicator illuminates in the IPC and the message center momentarily displays the preset distance gap. The vehicle maintains the distance gap and the brakes automatically apply to slow the vehicle to maintain the gap to the vehicle ahead.
When a MyKey™ is used and the MyKey™ max speed limiter is turned on, the vehicle speed cannot be set to exceed 130 km/h (80 mph).
I would consider it a serious design flaw if the brake lights are not activated when the adaptive cruise applies the brakes, especially since the stoplight switch is listed as one of the connections to the system.
-Rod
