Anyone had problems with 16 winshield?
StealBlueSho
NA
Here is the aftermarket brand XYG they stuck on mine from tbe dealership... This is the 4th one from this company... First 2 had defects and did not fit correctly.. creaked terrible when you drove.... The 3rd one the installer broke while installing... And this one now has a massive crack from bottom of passenger side almost all the way up... Gasket and sensor shroud look similar to PGW....
Sent from my Nexus 6P using Tapatalk
I've heard Carlite and PGW offer the best product. Part of the problem is that this is a thinner, "sandwich" windshield.
StealBlueSho
NA
Yea, the installer said it technically two pieces of glass with a substrate in-between..I could theorize of a bunch of reasons for this.. I would been upset but I didn't pay for any of it... The dealership did..
gimpy
Pennsylvania
With my 2016 sho, once I accede 65mph, there is a persistent noise that resembles air leaking.
My local Stealership doesn't seem to care and I'm literally 3 steps away from dropping a gallon of gasoline and a match.
StealBlueSho
NA
Go 64?? J/K....
limited02
Olathe, KS
Had mine replaced a month ago by Safelite using an aftermarket windshield. Costs $300 said and done and an OEM would have been $370ish. I'm cheap
Hoots
I think there is a TSB for air leak on the WS for the explorers? Not sure if it the same on the Taurus?
gimpy
Pennsylvania
I've tried to discuss this with the dealer and nothing was done, more of less shrugged off.
I'll take note of this and do a little digging to see if there is an issue of this sort.
Hoots
Here is the TSB (I think)
http://ford.oemdtc.com/1074/whistle...wl-panel-grille-cover-2011-2016-ford-explorer
I came across it in the explorer forum. I guess this was originally a 2011-2012 issues and people reporting it still hasnt been corrected at factory for the 16s and 17s.
Again, no idea if the taurus could have the same issue or not. Good luck!
Flylow11
Nashville TN
At certain speeds I hear a flutter noise from the windshield. I've checked everything. Even changed the wipers
StealBlueSho
NA
I have the same issue... It's seems to be a part of the lower shroud that vibrates..
tinkerkathleen
