Danielle
Ok. I just put on my new ignition switch. Ill look for the wire right now.If you type in Clutch Safety Switch into the search function, there are previous post you can look up issues with this switch. The link below is one of them you can try
http://www.shoforum.com/index.php?t...rank-neutral-safety-switch.12935/#post-109712
Here is a description from another thread:
the neutral safety switch, which is under the dash. Take a look under there, it should be right above the clutch pedal....pull the wire to the plunger type switch
