Denny
Taurus Homeland
This is a tie-in with thread: http://www.shoforum.com/showthread.php?t=45504
The SHO has been running hotter and hotter as the weather got warmer and warmer. Today it was down in the 50s and guess what, I wasn't running at N but at the A mark on the temp gauge, and I was lead footing it around town. I also decided to fill up when my favorite Shell station had $1.99 while everyone else was $2.27. I calculated my MPG....it was 18.5! That was higher than just five days ago when I filled up and calculated 15.6. Now the fill up last week was on a tank that I only touched the secondaries once, and that was because of evasive manuevering, otherwise I was testing to see how much fuel economy I could get by not succumbing to those secondaries. Well I've been in the process of moving and just like the previous tank, nearly all of my driving has been in town, lots of idling, lots of short trips, and speeds never above 60. I also wasn't easy on the gas by any means.
However, I also noticed that on these hot days, when I would turn the key on, I would hear the fuel pump gurgle for a second, then once started, the initial idle would be rough and you could the gurgling again. After some revving it would get back to normal until the next startup. Today, the gurgle is completely gone.
So...I'm thinking I have a bad fuelpump? And if so, would that cause me to run lean, and if I am, then this would explain the completely hot engine running?
I ran codes, all clear, yesterday, the day before, and today. Is there anyway to test the emissions or air/fuel ratio??
