doclees
This is an ongoing saga folks. Here is the background. 93 atx. Over the past 3 years has had intermittent no start issues. This means turn the key and nothing. I am on the 3rd LLT starter in 3 years. Battery is good. 12v engine off. I had issues with the ignition switch that may or may not have had input to this problem. I just replaced that switch with no change in the problem. Up until today I have not had the Alt light come on. The car would start. Drive a little and maybe no start. Let sit for 1-4 hours and it starts again. This morning I cleaned the neg battery post and clamp type cable head. Seemed to give me a stronger alarm beep. I drive to work and the Alt light comes on only over 1500 rpms. Lunch I try it again and no start and week alarm/lock action. I clean the neg battery cable again with it sometimes setting off alarm when connected and sometimes not. I clean the pos cable clamp and post. Strong alarm and lock action. Start up. Alt light still only over 1500 rpm. Starts up a couple hours later. I go home about 25 miles away. Alt light sometimes doesn't come on until 2k rpm. At home I park it and restart it. No problem. Now alt light constant but flickers sometimes. tonight I check a prong connector on alt. No change. Car starts no problem. Volt meter give me 12.05 engine off. 11.50 engine on. Is there a positive test for alt function I can do at home with my voltmeter? Why reliable starting now but alt light? Could I have stressed something to **** the Alt?
Had to drive car today about 5 miles. Started fine. Was at location about 20 min. No start. Lots of relay clicking. reseated bat cables. No change. Lights strong. Alarm strong. Windows weak. Had someone try to jump it. No change. Got a ride home. Help! I'll go tonight and it will start.
