FAST4DR said:
I had the lady pull a Bosch Platinum 4301 and it is IDENTICAL in size so that would work fine also.
Just because the Bosch plug
appeared to be the same size still doesn't make it a good choice for the SHO.
The Motorcraft plugs, both the AGSP32PP and the AGSP32FM are double-platinum, meaning both the center electrode and the ground electrode are platinum (actually, an alloy of platinum and nickel). With the Bosch plugs (all varieties) and most other aftermarket plugs (Autolite APP3924's are also double-platinum), only the center electrode is platinum, and the ground electrode is usually nickel or a nickel alloy.
Countless people have tried the Bosch plugs in their SHO's, the majority with poor results. I was a big fan of the Bosch platinum plugs in the early 90's, and found them to be excellent in certain applications. Unfortunately, they simply do not perform well in any flavored SHO motor.
sdpatt said:
That height difference shows me that the FM plugs are not designed for the SHO engine.
Scott, you are correct, however, the AGSP32PP plug has been officially discontinued and supplies are now becoming very limited. Ford no longer produces a plug specifically designed for any SHO motor. The AGSP32FM has been specified by Ford as the acceptable replacement. While it would be ideal if the PP's remained available perpetually, I don't think it's unreasonable for Ford to discontinue a plug designed for a motor which hasn't been in a car that has rolled off their assembly line in 10 years now.
I was as big a promoter as anyone of using the PP's, but the reality is that Ford no longer makes them, and they are becoming increasingly difficult to obtain. We've been installing the FM plugs in V6 SHO motors for about a year now, and haven't had a single problem with them (probably about 30 cars). They fit fine, and there is absolutely no problem with the plug boots (on OEM wires) seating properly.
The FM plugs (AWSF32FM and AGSF32FM) were factory installed in the V8 SHO's, and we've installed over 450 sets without a single problem.
The FM plugs are of superior design to the older PP plugs for a number of reasons that I won't go into here. BUT, they are still only a 60K mile plug. Ford says they are 100K mile plugs, but in our experience beyond 60K miles the gap will expand significantly, negatively affecting performance.
In any case, $24 for a set of genuine Ford/Motorcraft plugs available over-the-counter at autoparts retailers nationwide, which fit and work perfectly in the V6 SHO, is a pretty good deal all around.
