andy1
I had my AC recharged and it worked great but the following day I had nothing but hot air. I read somewhere about a cycling switch may be the problem or maybe the clutch. Where is the switch located and is it an expensive part ?
Are you sure that switch can be replaced without discharging the Freon? I thought it came into direct contact with the Freon? Or is there a diaphram in the top of the reciever to isolate it?.....
The cycling switch is under $20 bucks at PartsAmerica and can be replaced without discharging the refrigerant......
Without a set of guages ($60 bucks at PartsAmerica for a 134 set), you'd only be guessing at what the problem is.
Steve[/QB]
