abs help
mike25
92 sho
south carolina
i have a 92 sho my abs was working fine today but i had the hood opened and it rained when i went out to close it the abs controll was soaked and now the abs light stays on how do i check to see what is wrong?
tompumped
VT
I guess the water could've. It should be obvious if it was right after the incident.
There's someone in the classifieds that's selling an abs controller for $5, but I didn't check yet to see what your codes mean.
tompumped
VT
You can search online for wiring diagrams, I don't have the link I forgot to bookmark the website it was a russian website?.
In the diagram you will see which valve you have to test the resistance on for the code 22. I don't know what it should be, with mine there was no resistance it was open. The connector you will be doing the test on is the 19 pin connector the end you want will have pins sticking out it goes to the bottom of the valve block.
With the 63 I don't know what testing can be done for the pump motor speed sensor. Someone has to though. Or you can research and find out.
mike25
92 sho
south carolina
im gonna try and replace the abs control first yesterday i tried to pull the codes and it wouldnt give me any the light would just come on after about 10sec and stay on
