abs acting weird
92yamaha
ky
Hey guys, i am stuck with another sho problem. Here is what happend, I was driving to class and the abs light came on, when i stopped at a light i turned the car off and then on again and it was off.
A day later i was driving again and everytime i pushed the brake pedal the car acted weird , it kind of got more throttle by it self, the ac turned off and on by it self, the radio shut off and on, but the car had good brakes.
Then after about 5 min. drive it began to stall somehow and the abs light came on again but after a little it went off. So i kept driving home expecting something to blow and noticed that when i turn my turnsignal on the car did the same thing as with the brake pedal. I guess it is something electrical. The car starts fine.
So , if anyone has any clues throw it out here, i am stuck with it.
The car is a 92 MTX. thanks
projectSHO89
SHOless In St L
Your electrical symptoms are of low system voltage.
That means battery, alternator, or cabling.
Start with load testing the battery. When they get weak, the electronics in the EATC and radio start to act up as you noted.
Steve
92yamaha
ky
problem fixed!!!
Here is what i did. First i noticed that i am low on brake fluid, so i added some, but i knew that this wouldn't be the reason for the car to act like it did, so i turned to the battery, got a new one cleaned the connectors and the car runns great again. I am pretty sure that it was something with the battery although it did start the car fine, but anyways i am glad i got it fixed.
Thanks for the replies guys.
