Ok.. I have a 93 ATX. I just put all new upper gaskets on and checked the valves. The previous owner just did the 60K it looks like but put the old gaskets back on for some odd reason. New plugs and plug wells all clean. I fired it up and still had a nasty knock so its rod bearing time. I have never done this on an SHO and have read through a lot of back posts and get the gest of what I am in for. I also found the page with instructions for doing it so I am not worried about the actual process. My questions are as follows.
#1 Has anyone seen the crank damaged on one of these? I dont know how long this things been knocking but it sounds pretty bad.
#2 The car hs 115K miles and with the valve covers off is very clean like the oil has been changed regularly and was fairly well taken care of engine wise. What might have caused this rod knock in that case? The car had plenty of oil in it when I got it. Not real clean oil but I have seen worse so I dont think the previous owner through oil in to make it look better than it was.
#3 How hard is it to rod out the cats with the Y pipe off the car. I am sure they are wore out and we dont have emissions here. This wont cause any ill effects I wouldnt think since I have done it on plenty of stangs. Should make the car sound meaner though.
Thanks in advance.
Thanks in advance.
