A/C suddenly shuts off
javon7065
Philadelphia, PA
So this is a new one for me. Driving along yesterday afternoon with the outside temp about 90 and the A/C just shuts off meaning the blower motor as well. All the lights on the HVAC control touch pad below the radio go out. I'd been driving for about 15 minutes. I turn it back on via the "auto" button and then it shuts off again after a few minutes. Do it a 3rd time and after it shuts off again it will not turn back on. I head back home after this. during the drive back, I turn on the ventilated seat and although I hear that blower running the seat never gets cool. At home I try to turn on the AC by either hitting the "auto" button or just the A/C button and nothing is turning on. No error messages anywhere.
Later that night I go to shut the windows and figured I would give the AC a go. It turns again after I start the car with no problem. And it runs for a few minutes as well. Given this happening I am wondering if this should be a trip to the dealer since I have the ESP or if it is something minor.
Any suggestions are much appreciated!
Majestic
FCIM most likely. Mine stopped doing it as frequently when I replaced the battery. If you have the warranty, I'd take it in as the entire dash has to be taken apart to replace the FCIM. You can usually turn it back on with the touchscreen, btw.
Majestic
If they replace the FCIM, see if you can keep the old part. I would be interested in buying it and sending it off for repair as I've been unable to locate one.
SHOrod
Torrie Tuned
Cedar Rapids, IA
I think I still have my old one from my 2013 Lincoln MKS. The driver's temperature increase button failed on it, but all other capacitive buttons worked. The capacitive touch IC was obsolete and I was not able to identify a drop-in component, but if the SHO uses the same IC as the MKS, then I should have a few extra working ICs if you're handy with a soldering iron.
I hung onto it with the idea that if the used FCIM that I replaced mine with failed, I'd use the two to make one work again, but last year I traded in the MKS so I no longer have a strong desire to repair the FCIM.
-Rod
Majestic
Thanks, SHOrod. I believe you offered me this before and I appreciate it. I have no idea if the MKS and the SHO use the same part. I wouldn't trust myself to solder the circuit board. Thanks again, though.
mooniesdl3
NC
I had my 2016 do exactly the same thing, on off on off when ever it wanted to. It was the touch pannel.
javon7065
Philadelphia, PA
That’s good to know. Already the climate button on the touch panel doesn’t work. if I want to turn off the whole system, I have to go onto the Sync screen to do it. Going into the dealer this Thursday for them to have a look. I’ll post an update afterwards.
Tbird6
Our 2013 MKS Eco also had this failure but I could not find a new panel? NLA from Ford?
All I could do was send it off for repair and that did work 100%.
javon7065
Philadelphia, PA
I am not sure what NLA means but I am going to the Ford Dealership on Thursday and I have the ESP that should cover it.
Tbird6
No Longer Available.
Hope you can order it and since mine is a Lincoln I guess the panel is slightly different?
mooniesdl3
NC
It was listed the same for mine but the dealership didn’t have any trouble getting it. I was originally going to replace it myself but was unable to source a new one.
Tbird6
So you were able to get a new one?
Not sure what your saying?
javon7065
Philadelphia, PA
So here is an update on this issue. Took it to the dealer. FCIM was replaced and covered under the ESP. However, the day I got it back the same thing happened again. Twice that day. So I figured I would give it a few days to see if it would be consistent. It was, but only in that it shut off. When it did was not consistent. Dropping it off tonight again. If they have to remove the panel again I am going to try and get a new radio to get the latest version of Sync. I'll dig up the threads on here to see if I can still get a new model.
Use that ESP like it owes you money. It does- and good on you for getting one. Word to those that have one that is still eligible, good idea with so many complex systems in electronics and powertrain.
Battery. 99% percent of issues with electronics seems to be battery related in these cars. Even, if your battery is good or new....if might now be good. My car ate batteries every 2 years like clock work.
javon7065
Philadelphia, PA
That’s exactly why I got it for items such as this. While I’m not a mechanic, I am an IT guy and I know that troubleshooting something like this can be annoying because it’s intermittent. However, my experience tells me that when something like this happens, it could be a sign of a bigger problem as well. Probably not since I’ve gotten a bit more comfortable that nothing else is gonna shut down on me at this point. Thankfully, it’s not my daily driver so I can let it be at the dealer for as long as it takes.
thanks for this information. While a previous owner did keep good records. I don’t know how old the battery is and it’s a Duralast which is not a great brand, correct?
I bought the Super Start AGM battery from O'Rielly. They have a decent warranty, but like I said my SHO ate them every two years. If I could go back in time, I would probably just buy the stock Ford AGM battery and bite the bullet. The SHO was designed around that battery and would have probably lasted longer. Also if you don't daily your SHO, a battery tender would be a good thing.
javon7065
Philadelphia, PA
OK, thanks for the recommendation. I do drive it once or twice a week so isn’t that enough to not need a battery tender? And if I don’t drive, it at least twice a week I’ll certainly start it up remotely and let it run.
boookboy
Staff online
