93rev2sev
OK, removed rear mount, got that little heat shield off and was surprised that the whole VSS and cover came off with it. That made removing the forkbolt easy. Got the new VSS installed on the cover and set it all back together with the 2 cover retaining bolts and I'm having a helluva time getting the speedo cable back in there.
Something tells me I should have put the speedo cable in FIRST and THEN installed the VSS/cover/heatshield?
If that's not my problem, I think I'll be removing the y-pipe and rear exhaust manifold. That'll give me plenty of access to the area so that I can employ that aluminum heatshield tape in all the right places and clean up the area. I think there's a seriously leaky rear cam seal in there, because I was covered with grease and oil from fingertip to t-shirt sleeve.
