95 ATX keeps blowing 10amp underhood fuses
95redshoATX
MA
So i was driving down the road when my car suddenly died, cranked the ignition and i hear no fuel pump.. i did a little research found out that one of the 10amp minifuses under the hood could be the problem.. sure enough it was blown, i replaced it immediatly.. drove another mile down the road and it blew the fuse again.. i went through about 5 fuses in 15 minutes just to get the sho back home... What could be causing this problem??? ... i read somewhere it could be the coolant level sensor?? is this correct.. any help would be much appreciated... thanks guys
hawkeye18
Sorta cares
Norfolk, VA
Definitely. The coolant sensor shorting out will blow that fuse and render you unable to start the car.
95redshoATX
MA
well.. that seems like a simple enough solution haha.. if i unplug that sensor the car will run no problem but the coolant level light will not appear if there is low coolant right?
ribeye2065
