I'm working on my brother's '94 automatic trans car and it's really hard to start sometimes. After sitting awhile, if i turn the key forward it'll only have about 20#'s of fuel pressure. I tried doing the key on/off thing to build fuel pressure and it'd build up to 40ish #'s. I have to play with the throttle to get it started.
Floor it, pump it whatever it takes but after trying a few times it will start and it sounds fine and revs without a problem.
The weird thing is that it'll crank crank crank and then stop and the lights almost turn completely off. Seems that it's drawing all the juice from the battery.
I searched this site and found people with similar issues and i don't know if this is the same.
Thing's i've done/checked so far:
changed the crank position sensor
checked the crank sprocket keyway and it's fine.
Questions:
What should the timing be set to while running?
How do I check the ignition components to see if they're ok? I have the ford repair manual but I guess there's a diagnostics/electrical manual that I need.
What's the best manual to get for these cars? The haynes Taurus one doesn't have much about the SHO.
Thanks.. hopefully we can get this car back up and running and not have to part it out.
Questions:
