93 shuts off
gpete
fall river ma
can anybody help i have a 93 sho and it shuts down sometimes i have spark and i have fuel i have tracked down the problem it is the fuel pump not purging the system i do not know what to check next help
Huntervf
Bored now
Back in Michigan ... again.
Moved to gen I/II maintainence :thumb:
Need more info; could be a bunch of things but a common SHO problem like this is the crankshaft position sensor (cps). Crank the car and watch the tach, if it doesn't move then you need a cps. Try doing a search for CPS, crankshaft sensor or "car stalls and/or won't start"...see if those results sound like the problem you're having.
gpete
fall river ma
i do not think it is the cps it cranks over and the tach moves it has something to do with the fuel pump when it stalls and i try to restart it the fuel pump is not coming on what do you think it could be
