93 atx tranny
andy1
California
I am the original owner and have 131,000 miles. At 100,000 I replaced the plugs and wires plus replaced valve cover gaskets. The valves were also adusted. The car has been babied and I am starting to get a little slippage between 2nd and 3rd. Does this mean I have to overhaul or can something be done to correct the problem. Thanks
Groo
Glenview, IL
A little slippage here and there isn't the end of the world. However, once you can't get into 4th gear, it's time for a rebuild. Ie if you press your overdrive switch, and nothing happpens.
Have you checked the level of your transmission fluid lately? How often have you had it flushed? If you haven't been doing it on 30k mile intervals, it's too late to start now. Just make sure the transmission always has enough fluid.
The 93 ATX trannys are the weakest ones, and are the most likely to go.
BeatDaSHO
Hatboro, Pennsylvania
not to be mean andy1 but what kind of car do u have?? ATX or MTX? when i first read it, i thought of clutch slip so please give us some more info. Thanks.
Greg
dlmech
Atlanta, Ga.
More than likely it is something in the valve body like a broken clip in one of the piston assy's. which is common. Or you could have a bad 2/3 shift accumulator piston/"O"-ring. Unfortunatly the tranny has to be dropped out to remove the valve body.
Randy
BeatDaSHO
Click on the 'Profile' icon, and see the profile info given at registration.
However, it is very helpful to readers if such pertinent info is clearly stated in the posted question.
Some people just don't put a ton of crap in their signature.
<small>[ June 09, 2002, 01:19 PM: Message edited by: projectSHO89 ]</small>
F-22 Raptor SHO
7015 feet above Sea Level
Uh guys, my eyes tell me the answer to the question was in the title..."93 ATX tranny" Seems pretty clear to me. Guess you all need to read the whole thing before you give a guy the smackdown.....
