Justin Ashmore
- Joined
- Sep 21, 2017
- Messages
- 10
- Reaction score
- 2
Have a 92 mtx so couple months ago car lost power and dies on hwy. had it towed wouldn't start. So the process began. I replaced the fuel pump and filter. Next was the water pump. Car started up ran fine then one day it started to gasp for air. Made the sound 3 times and died would start back up but then would make sound and die. Car has been sitting cause won't start. So I replaced the ect , pcm, icm, coil pack, spark plugs , wires, belts and timing belt, cam sensor , crank sensor, knock sensor, injector gaskets,. It started ran good 2 days then it came back again. Rpms drop to 0 while in gear. I am now to a spot I don't know where to go next. Any help or leads would be appreciated. Oh and this is the first car I have ever worked on. Thanks
