Pull your codes so we can see what is going on with the engine. Depending when you last pulled your codes, you should clear them first and then pull them after you get another low power event.
Doesn't look like any of those codes should affect your performance. For the BOO switch code, do your brake lights work when you step on them. Did you do a quick check to see if your rear brakes are hanging up (not releasing). Is your gas mileage normal?
So when you say the car is sluggish, can you tell if the engine is missing or running fine but just no power. Is your crank bolt tight, as that can affect timing.
the crank pulley bolt you referring to ? It only runs sluggish when the CEL comes on like for instance if I'm driving while the CEL is off it a run good and open up like a SHO should but soon as the CEL comes on it bogs out in kinda of a limp mode then it runs sluggish again but I pulled over after work to run another test with the OBD1 scanner and I those same three codes then I turned the engine off and tested it with the key on and I got code 215 which is a DIS fault coil #1 so would that be my DIS module ?
http://www.shoforum.com/index.php?threads/cel-paperclip-method.130935/#post-1438863
I had a 95 MTX that stumbled and had low power in the first couple of gears. There were no codes and it ended up being a bad fuel pressure regulator and bad spark plug wires.
