sperold
Last to Know
Primary Crash Sensor Circuit open or High Resistance is the listing for a 9 flash situation.
Figuring that it was a harness issue, I unplugged the 2 connectors on the module under the dash and the crash sensor at the front of the car.
Did the continuity test on the harness and found that all 4 wires were continuous.
So now what do I do?
Which component is a better bet to swap, the module or the sensor?
Took some part numbers: F0DB-14B006-AE for the sensor, and F0014B056AA or "with foam" F1DF14B0056AA for the dash module. The dash module had a build date of Nov 1992 which suggests it is not the original.
Any advice appreciated.
