bryantaylor
SHOme yur bewbs
just bought a 90, not running. it was sitting for a couple of years, ran when parked. but now the fuel pump doesnt work. if you spray starting fluid into the intake it run start for a second or two, then cuts off. it has a brand new pump, i took it out and tested it, and it does work. put in a new fuel filter too.
here is where it gets interesting. i jumped the fuel pump and ground on the test port and pump doesnt turn on, not a big deal, i was expecting that. but when i jump the test and ground to run the codes, nothing. the CEL just stays on, it doesnt flash at all. i will pole around some more on it tomorow to see if i can find anything. anyone have some suggestions on things to check?
