stlooiesho
It happens after the car is warmed up, but it is random & it happens under a various conditions such as acceleration or steady-state cruising. Sometimes it occurs once or multiple times, sometimes mild or so severe that I have to push in the clutch. It may or may not still happen after I re-engage, so i'll try to downshift and/or coast & try again. There are no codes. When it happened having oil & fuel pressure gauges hooked up, there was no significant variation before, during or after. Seems to happen more often when it is warmer out, like between 70 & 80 deg. This morning, it was about 55 deg, and it did not happen at all going to work, a drive that lasted close to an hour. Could it be a MAF sensor? Would a bad MAF throw a code?
Question 2, I have an Autometer A/F gauge, I have a t-tap connector on the front O2 sensor, but it is only displaying a full rich light. When I tried tapping the other wire, there was no light at all. Of the 3 O2 sensor wires, two are white, one black. Which white one should I be hooked up to?
So, it was fresh in my mind...
