Ummm, how come your car's HP & Tq curves don't cross at 5250?
I saw that too, very interesting...
.Even with the different scales, I'm pretty sure the steepness of the curve would change vertically, but has no bearing on the horizontal crossover point (rpm). The X axis is consistent, rpm vs rpm. Something's up there.
oh yeah not sure if this had anything to do with it but instead of welding a seperate bung in the y-pipe for the a/f pickup sensor on the dyno they simply removed my front O2 and put the pick up in there.
You guys think I need more cam to feed this thing? Shouldn't the stock 3.0L cams be good enough to make north of 210whp with this size engine?
X2Damn its too bad we can't see the AF ratio. I think 13-14:1 is way too lean. I find I make more TQ in the 12.5 range. .
I would rerun it with higher octane fuel... What did your timing look like (are you data logging with a TwEECer)?
How much smoothing is applied to that graph. I can still see some jagged lines, but like Ransom said, it looks like you may have been consistantly backed off timing the entire run. Also, was it lean before 2,500 RPM?
I also shoot for 12.5:1 - 13:1 on an NA SHO... 12:1-12.5:1 on boosted SHO's.
Just because he said he went to Doug in his first sentence doesn't tell me a flippin' thing about the TwEECer. He said he had it dyno tuned, but still never mentioned anything that said whether or not he used a TwEECer :shakehead
Okay smart-ass... Word comprehension here.... I asked if he was using the TwEECer. You said that he probably didn't as Doug from FPS was tuning, then asked me if I missed that [Doug]. I then said I don't keep up with other people specifics.
With your remark you assumed that I knew that Doug doesn't use the TwEECer or the OP didn't already have one. I was replying to the fact that I don't know what who uses anymore.
You definitly need 93 octane in that high of a compression engine. I'd stop at a Sonoco and add some 100 octane as well to get the full beneifts of that compression ratio. I only run a minimum of 100 octane in the GTS and it is 10.75:1- most times I pick up jet fuel
Higher octane, a redyno and probably a retune will most likely get you where you want to be.
