It has been a busy Christmas break for me with the family and the car. On December 21, I performed the upper end 60K, the valve gapping, plugs, plug wires, intake gaskets, injector seals and added O-rings to the valve cover bolt bushings. On December 28, I replaced the timing belt, accessory belts, cam seals, crank seal, CPS, CID sensor and the crankshaft Woodruff key.
Today, December 30, I replaced the connecting rod bearings. Several of you had expressed your curiosity about what rod bearings would look like after 269,000 miles (within a hundred or so). Well, here they are. Click the link below and enter the guest password shown below. You can select from the three photo albums for the different services I just performed.
Link: 269k SHO services
Guest password: 269k
Albums:
269K Valve Gapping
269K Timing Belt
269K Rod Bearings
Just as many of you suspected, even without a noticeable rod clunking sound, the bearings were well into the copper of the bearings. The engines that I have serviced with fewer miles than mine (isn't that all of them?), had a smoother, tighter sound as they idled and reved. The wear of the many miles that have rolled under my car is evident in the pictures of those bearings. No flattening or deformation, but smooth and significant wear of the bearing material.
The rest of the engine's lower end seemed to be quite solid and the oil suction was so strong that it was difficult to separate the rod end from the rod and then to pop the bearings off the journal. I found a drill bit (smooth end) that fit into the oil hole tightly enought that I could easily "lean" the bearings off the journal. I used one of the many plastic spray tubes from the cans of intake cleaner that have spent time in my garage to push the upper bearings around the journal.
The car is still on jackstands as I had to fit my work into a day with one of my daughter's 2nd birthday parties and my mother-in-law's birthday dinner. I found that the two 10mm bolts that attached the oil pan to the clutch bellhousing to be stripped and I suspect that at least one of the shops that did the several clutch replacements may have had something to do with that.
I used a thread repair kit to install steel coils in place of the stripped aluminum. With the completion of that repair and the installation of the starter, oil level sensor, Y-pipe, O2 sensors and new exhaust donut gasket, she should be back on the ground. Hopefully with a new lease on life. I'll say my prayers. (Later: prayers were answered).
<small>[ January 02, 2003, 10:07 AM: Message edited by: sdpatt ]</small>
Albums:
269K Valve Gapping
269K Timing Belt
269K Rod Bearings
