4th Gen GT350 Brembo brake mounting kits
SemperTim
Miramar, FL (Miami)
Finally available, I have a small production run of 20x Mounting kits to fit the 15.5” 6-piston Brembo brakes onto the 4th Gen Taurus (and equivalent Flex, Explorer, and Lincolns).
$595 shipped
Included:
2x Adapter brackets
2x rotor spacers
4x adapter bracket bolts
4x caliper bolts
2x custom DOT brake lines with banjo bolts and washers
Caliper hardware kit
What’s needed:
GT350 Front calipers (remove bleeders and crossover tubes and swap between calipers and sides)
GT350 Front rotors 15.5”/394mm
GT350 front brake pads
Extensive research was done to ensure brake sizing was appropriate. These calipers are ~12% smaller in piston area resulting in slightly more pedal effort (less squishy) and better modulation.
I’ve been running them for a few months and a few thousand miles. I could not be happier with the performance and the look isn’t half bad.
D722b4ed06cefc9abffc9a906762ecfb
9426922d474605a359aff4e025d3f9a2
C2d96f1cf97a53e7123acfe1de74d86b
313tiger
