4th Gen GT350 Front Brake Upgrade
SemperTim
Miramar, FL (Miami)
Nice...just wanna double check these will fit a 2018 Flex.
Yes. They use the same spindles as the Taurus and the Explorer. Only thing you’ll need to confirm is the clearance for the calipers. For the Taurus V 20s, they need 19mm wheel spacers to clear. It’ll end up with right at 1” of total spacing with the rotor spacer that is included.
the_hargis72
Houston
Thank you...I'll double check. My flex has factory 20s with 39mm offset.
TuxedoBlackTaurus
Texas
Just want to confirm that this is the same person on eBay that is selling the kit?
Because I’m in the process of acquiring the parts.
IMG 2434
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
Tim Spencer sells them. I’d say that user name is Tim. I’d be comfortable buying them. Tim probably needs to get them sold and the normal SHO channels haven’t helped enough so he’s on EBay. That’s my take.
Michealb
