4th Gen GT350 Front Brake Upgrade
SemperTim
Miramar, FL (Miami)
Nice...just wanna double check these will fit a 2018 Flex.
Yes. They use the same spindles as the Taurus and the Explorer. Only thing you’ll need to confirm is the clearance for the calipers. For the Taurus V 20s, they need 19mm wheel spacers to clear. It’ll end up with right at 1” of total spacing with the rotor spacer that is included.
the_hargis72
Houston
Thank you...I'll double check. My flex has factory 20s with 39mm offset.
