eli terry
Changed the thermostat and checked the cooling fans. Drained and refilled the coolant system installed a new radiator cap. The cooling fans do come on with or without the climate control running. I did a search on the V8sho.com site and ran across a statement made by a repair person stating that gen two's had pump failure at around 60k and was common. But the gen 3 on the other hand seldom have water pump failures. I have run out of ideas as to the cars overheating issue. My last idea was to replace the fan temp relay but they are working? So what I'm thinking could it be a circulation problem and be the water pump? Any advice would be greatly appreciated.
