I am on a bummer and have a problem. I spun #5 rod in 1994 SHO 3.2 ATX. Going to rebuild and cannot find main bearings. I can polish the crank and the old but good mains I took out of my spare 3.0 1990 SHO MTX, if I cannot get new ones, then have the rods turned on that crank. Also the rod may not be able to be resized. Please help if you can. The crank from my 3.0 is like new and am thinking about putting it in the 3.2 block, any problem? I don't know if these are internal or externally balanced as I would need to use the flex plate instead of the clutch flywheel. Also am thinking about using all the rods from the 3.0 in the 3.2. They are the same length but the crank end is made different than the 3.2, the 3.0 have a large balancing tab. I know I cannot mix and match the rods but maybe keep all 3.0 crank and rods together. Would that be a problem? Also I noticed that the piston pin end of the rod has a different size pin diameter. I haven't checked yet but I think the hole in the rod is the same on both but the bushing has a different I.D. if that is the case I think I could get new 3.2 size bushings installed in the rods. Thanks Larry
