3.2 conversion stuff
operdot
USA
Hi i am finishing a 3.2 swap where i kept the single accessory belt system and used the atx computer, this is a 93 car with the starting selenoid on the starter, i forgot where the 2nd positive heavy guage wire goes, it seems as if they both connect to the same copper stud, but i'm not sure since the 2nd wire runs to a fuse block,
another thing is how do i get the backup lights to work? the switch seems to have a different harness then the one on the atx, can i just modify the plug?
The clutch pedal has a starter breaker switch on the 89 but i couldnt find the plug on the atx.
and the last thing where in the world does the horn sit in the 93?
nkb93
SLO 4 SHO
Charlottesville, VA
PM me your email address and I can send you some info regarding the reverse lights and clutch interlock for the starter.
