2015 Front Right CV Shaft For AWD SHO?
Darkside_Prime
New Hampshire
Does any one know the exact part number for a full shaft and where to find them? ie what part store actually carries the AWD Front Passenger Full CV Shaft?. Mine is not a two piece And all I can find is FWD style CV Axles. Which with PTU for AWD has a much longer machined shaft input section and hanger roller bearing mount .
Sent from my SM-S918U using Tapatalk
Jordan_R
Missouri
There isn't a single part number. It's two pieces like you said. Therefore two part numbers
kryptto
South East, Florida
Year & PP or non PP?
LilCop2002
In the South.
When I did my CVs I could not find the single one-piece axle so I had to order the two pieces. Unfortunately I did not notice the difference until the front end was already apart.
BradM
I just replaced my passenger outer axle, part TX833 Motorcraft on Amazon (a really good price), for a 2017 Taurus AWD 3.5EB (SHO, Interceptor use the same axle). The inner axle should not need changing unless the hanger bearing is bad.
LilCop2002
In the South.
That's the issue... The OP and I both had single-piece (full-length) CV axles. Where your inner and outer meet and can be replaced independently, ours has a ~3 ft axle.
I swapped mine to the inner/outer version December 2022 and never looked back.
lingyuair
