frankanthony
I finally completed a 2 week long project on my car and have only been driving it for 3 days. The current issue that I am having is when idling the car will sometimes "bounce" from 600 to 800 rpm but sometimes it will sit solid at 600 rpm and act normal. I also discovered today that when I am idling and turn on the AC it will immediately rev up to 1k and then "bounce" again and sometimes create a more intense jerking feeling which I don't think i have experienced with the AC off. The AC rarely works and I was going to attempt to recharge it this week but I figured I should look into this issue first incase they are related. Btw putting the car in P - R - N - 3 - 2 - 1 with my foot on the brake doesn't seem to change anything. Thank you for your time and help!
Here is a list of repairs/changes to my car in the past 2 weeks. Thanks to the help of previous posts and articles in this forum! :thankyou:
Car repairs... Replaced transmission and torque converter (used 87k), New Magnaflow exhaust, new O2 sensors, new flex pipe, new front wheel bearings, new drivers abs sensor, new front left upper strut mount and bearing, new front sway bar links, front brakes, new transmission lines, new power steering line, power steering fluid flush, new right outer CV Joint boot, new starter relay, removed saxacone, new air intake accordion tube, new air filter and pollen filter.
