1993 Wont start
moonbum
PA
I have a 1993 SHO with a new Cam sensor, crank sensor and DIS module, the coil has power to it, the cam belt is NOT broken. Car turns over but WILL NOT START and has NO SPARK ??? Can anyone help with any ideas what's wrong ???? Thanks
Dirk37
Mr. Resourceful
Washington
If the coil has power to it and you're not getting spark, that sounds like a bad coil.
Can you give us some more info?
When did this start?
Has the car been sitting or did it die while driving?
projectSHO89
SHOless In St L
Just because parts are new does not mean that they are a) good and b) properly installed.
You're going to need to do some in-depth diagnosis to see if you're getting the CPS signal and if the DIS is firing properly.
most common failure in the scene you describe is that the new crank sensor was not gapped properly and has been destroyed because of that. are you absolutely certain that the crank sensor was gapped properly?
moonbum
PA
More info
According to the previous owner it just wouldn't start one day and ran the night before. New crank sensor but don't know if it was gapped right, has power to coil though but no fire when it cranks over
moonbum
PA
I did not install the crank sensor, I just boughtthe car non running for a steal so I am starting with what I know. I do know the Crank sensor was replaced although I dont have that much faith in the genius that installed it so it may be junk now. It does have a leak at the fuel pressure regulator when you crank it over the feed line is leaking where it enters the regulator. Not severly but it is leaking. That wouldnt do it correct ? So HOW do I test the Crank sensor ? Greatly Appreciate the help !!!
moonbum
PA
What should the GAP on the Crank sensor be ? I just ordered a factory manual and dont have it yet... Thanks again.
moonbum
PA
The guy I bought it from said one day it just wouldnt run, ran the night before but the next day wouldnt start. I checked for loose wires, I was told a ground wire could also cause this issue ? I dont see any loose. How Many Ground wires are there on this that may impact it running and where are they ? Appreciate the help !
Racer X
SHO Pilot, Retired
Connecticut
The DIS module on the intake is grounded via a strap at the back of the intake, to the firewall. If that strap, and the brackets that attach the surge tank to the rest of the intake are questionable, or missing, then you would experience the issue that you're describing to us now.
Check those connections and get back to us.
AREA 91
PA SHO SHOP
Area 91
Where in PA are you located?
Sounds like you may need to tow it to my shop for a little sho love.
moonbum
PA
I am not far from you. I will remember that if I cant figure it out. Thanks
It needs to be around .030" - but the way the sensor is made it wants to be larger than that because the magnet is in the top part and it wants to clamp to the shutter wheel, which results in a dead crank sensor. So you need to verify that the gap is not too large.
A matchbook cover works pretty good for a thickness gauge in this instance.
