Plasticmatt477
No, it was as if it was disconnected from something... weird looking wire (looked like a curved plastic piece with a metal tab to insert something into... this was only long enough to have to go onto the piece where you put your key into) The curve is the same as the key hole cylinders curve so I assume it hooked onto that somehow... I simply taped it off and isolated it so it couldn't arc anymore.
The insulation was fine, but the bare metal on the connector was showing and thats what was arcing.
I hope thats the only one and I really do think it is. The turn signals have worked fine since, but the ABS light is back on.
Matt
Matt
