1993 SHO dies when it gets over 95degrees outside!
Raider
Oklahoma
It doesn't run hot according to the gauge, but when it gets above 95 degrees outside sometime it will die and wont restart for a while. No codes!
It seems like some component get to hot under the hood..maybe?
Could be a number of things.
When it faults:
Check for proper fuel pressure (approx 40 psi at initial key on.)
Check for spark including proper timing. Timing light comes in handy
Check for air (Crack throttle slightly while cranking).
At least one is missing. Once you know which is missing, you can focus on that subsystem to identify and correct the fault.
FWIW, fuel pump or CPS are both likely suspects, however, if you fail to follow a specific troubleshooting procedure, you're likely to just rely on luck alone.
