1/4 mile times
EJL3Lew
NJ
i have a 2010 SHO cold air intake 3 bar map 170 stat and livernois stage 4 91 octane the best with this set up is 13.16 at 104.7 but 2months ago i went 13.08 at 105.8 with out the the 3 bar map and only the livernois stage 3 and 89 octane and its cooler now what could be wrong ... Does anyone have any idea thanks
ElevenSho
Iowa
I would datalog and send it to the tuner to review. Unless your 60' is worse I would think you should be faster especially the trap speed.
You can ask Livernois if you have the latest version of their tunes. On the way to the final version, they had a "cold weather" tune version. I believe since you have a 3 bar map, you can run the 4X tune and 93. If 93 is not available, that would be the only reason to stay with the regular stage 4 tune.
BamSHO
South Williamsport,PA, US
Your running 91 Octane stage 4 correct? I had the same issues with the '12 when I first tuned it. Did you run with Trac OFF? Do you have the 4+ tune too? Just like Manu said, I would ask for the 4X tune, I have it and love it.
jtreber
Indiana
I'm just learning. So when doing a quarter mile, traction control should be shut off?
