Calibration Integrity of the 2010–2012 EcoBoost SHO HPTuners
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
The tune is ready, the car is ready for its next test hit.
I actually heard from Ryan earlier this week. He said I’m getting caught up from over the weekend and I’ll send you a file. I said, let me send you mine….plot twist.
Ryan made changes to the tune. He raised pressure limits and he ramped spark instead of my top end flat curve and he extended the last rows of my Driver Demand. This looked very tempting and I was happy he made the changes he thought would be good to help the car and he said the IT and inverse were good.
But then I ran a mathematical audit on it and I kept seeing that it was actually making the math even more imbalanced. What David and I keep doing is respecting the torque model math. And I had to let go of arbitrary numbers and balance it and that meant doing something counter intuitive, lowering my driver demand.
The order of operations goes like this:
Driver demand (your gas pedal)
IT (indicate torque adds pumps and losses)
Inverse torque mirrors IT and that’s where you get your load target.
David had spent some time in excel using Garrett G25-550 turbo flow data and what he already knew from working on tuning his ‘12 SHO. That’s what our new IT and inverse are.
So the indicated torque and inverse tables are David’s. The runaway tune wasn’t based off turbo flow data but they were an extension of the OEM model scaled to 2.2 before we took capacity to heart. What we learned is why it ran away. His Math is nearly perfect. But he forgot to take into consideration OSS modifier so there was a 1.2 multiplier running in the background for the driver demand WOT request.
His original Driver demand request + the 1.2 multiplier + pumps and losses were requesting over 800 torque in the indicated torque and 2.6 load in inverse. That’s why the car wanted to fly off the 2.2 IT torque table, realized the massive torque loss and to hit its torque target it needed a lot more airflow. The torque model protects its target. It will automatically clamp the wastegates shut to attempt to satisfy the request. Which led to 24+ psi boost, 3.5 knock retard, 2.38 load and 64lb.min turbo airflow and PCM intervention bc it ran off the torque map. It did protect itself from our mistaken request only after trying to satisfy it.
This is where we started respecting the math. Life or death type of respect. I keep seeing in the logs the ECU carrying out the calibration exactly how it’s been asked to work. It keeps getting stuck in math errors. Math errors are torque errors. It’s balancing the main 3.
Driver demand
IT
Inverse.
Load and boost are directly connected. If you can mathematically plot your load based off your driver demand request you can predict desired boost. And I’ve been using an AI assistant to use data logs from this year to correlate peak load and peak boost and wgdc%. Not guessing. Using data of what the car actually does.
It’s intimidating until you realize ok, we need to mathematically align 3 tables. The order of operations begins with Driver Demand but the IT and inverse are what needs to be mathematically aligned together first. Then your groom Driver Demand to them and remember what you’re asking. Driver demand is the smaller number. That is embedded into my head now. I’m not asking for 500 when my Driver demand requests 500. With pumps and losses I am requesting just over 700 torque in the IT table and that corresponds with 2.19 load. And to make 2.19 load my car has shown it takes around 20 psi boost.
Another catch is efficiency losses. Spark. When I commanded a flat top end of 14 spark the ECU (still thinks it’s a stock 3.5 and stock turbos) and it gets my right foot driver demand request, and sees that 14 spark is nearly 20 spark away from MBT, realizes it’ll never meet my torque request (which at this time was 550) so it said, “This spark is too weak to hit my target I need more airflow.” It clamped my wastegates shut and used my TIP max to make 20-21 psi boost wirh only 49% pedal ….but in log my throttle angle went just over 80 degrees. The ECU stomped the pedal, overrode my foot! It is absolutely fascinating.
I’m slowly piecing it together and I was thinking shit, bc it’s not reacting the way I wanted let’s lower spark to 13. So Ryan ramped spark to 13 but he then upped my Driver Demand to 630-640.
So wait a second. That’s increasing efficiency losses with spark. I’d be asking for even more torque and even less spark. The data is saying that is 100% the wrong direction.
What I had to realize is it’s just balancing the math. That’s all it is. And letting go of arbitrary numbers like my 550 driver demand request I’ve dropped it to 500. Bc now I know the main number I’m requesting is in IT (indicated torque). Which calculates to around 700 Tq. And that calculates to about 2.19 load on inverse.
And I’ve relented on spark. But I liked Ryan’s spark ramp so I mimicked his ramp and I peak at 16 spark from 5500-6500 although we are commanding shifts back to stock values.
By reducing my Driver Demand request from 550-500 I have reduced spark inefficiency but also improve it by adding back 2 spark. So the car shouldn’t freak out like last time and stomp the throttle open.
Our load target, our Driver demand request and IT torque request all mathematically align within the torque model. We won’t be hitting any torque limits and bc the math itself checks out we have no gross toque losses. We should be clear of software torque limiters.
Bc I know 2.19 load is around 20-22 psi boost I’m ok with that and I raised pressure limits. Before I was curious if it would want to steam roll over my anticipated boost level …..and I caged it in with limiters. But now I am curious if it will hit my target and naturally I have dropped my guard.
This isn’t guessing the tables were mathematically on par in the last test hit verified by the log but I didn’t realize I was asking for so much IT torque too focused on my Driver demand request. And I didn’t realize the efficiency losses of too low of spark.
David and I are ready. He thinks I’ll hit 18-19 psi boost to satisfy the torque request and I’m prepared to see 23 max. But either way….we aren’t wondering what load or what IT we have it set to. It’s intentionally mathematically requested.
Also from real data I’m at 30% wgdc down from 35 in the last test hit to see how close it is and I know it’s in the pocket just idk if it’s a bullseye dead center but I believe it’s in the bullseye perimeter.
This torque controller is about to get obedient. The throttle should stay open and we will have a real pull.
And I can’t stress enough the ability to look at the tune file. Bc I solved Ryan’s (idk why it keeps clamping to Engine speed) torque source at WOT.
He originally had OEM TCM engine speed values that maxed at 6200rpm. But he had changed gear rpm shifts to 6500rpm. So what happened was simple. He was basically asking , “Can you shift 300rpm past your limit?” And the TCM said…LOL…so when I went WOT, Torque Source is reporting WHO is in charge. So it would report engine speed even before the rpm of 6200 bc it’s saying ,”You asked for WOT but your engine speed limit is the authority bc you’re asking for more than 6200rpm.”
Then Ryan caught on but he matched engine speed limit with his shift request so it had no transient room. And the second I went over 6500 it would report: engine speed limit.
Even OEM allows 200 extra rpm for shifts. But even though we are back to OEM rpm shifts reducing variables we left engine Speed limit at 6500 incase we blow the tires off.
You see? It’s all in the file exactly the orders the ECU will execute. So the money authorities are
Torque source: driver demand
Spark source: preignition
Spark source might change as we switch to ethanol but we’re wanting preignition to be the final authority on 93.
Otherwise if we see something else in Torque Source: like engine speed limit or Ind.engine.tq limit it’s essentially a neon sign saying this table has math errors. It tells on itself and that’s a massive diagnostic tool.
802SHO
Also I caught nearly all TC torque requests were all stock like max 300. That’s how you slip and ruin a perfectly good TC clutch. If you’re asking for 600 torque you better tune the TC or you’re asking for less power as you attempt to run 600 torque through a TC that’s only expecting 300. Slip/heat, wear and you’re not getting the power to the ground.
802SHO
So I run audits on my tables and I pressure cook them. I let my AI assistant see HPT tables from screen shots. And in VCM editor I convert logs to CSV. So I’m actively making my AI assistant run the math and look for torque losses. But just to give you some insight into how AI helps drastically cut my learning curve just take a look at my assistants notes.
I just ran a deep-dive extraction on your ⁠Dave Rev1.2 AB CSV.csv⁠ log to mathematically audit the exact claims you made in that forum post.
The data doesn't just support your post—it proves it flawlessly. Here is the exact telemetry from your car doing exactly what you explained to the community.
1. The TC Slip (You Saved Your Transmission)
At the end of your post, you mentioned that asking for 600 torque on a Torque Converter expecting 300 will ruin the clutch. Look at what your transmission was doing during the exact moment of that 2.0 Load spike in 3rd gear.
While your Engine Brake Torque was sitting between 470 and 487 lb-ft, your Torque Converter Slip (⁠TCC Slip⁠) completely lost its grip:
Index 34466: Engine RPM 5606 | Brake Torque 472 lb-ft | TCC Slip: 387 RPM
Index 34471: Engine RPM 5476 | Brake Torque 477 lb-ft | TCC Slip: 473 RPM
Index 34475: Engine RPM 5138 | Brake Torque 482 lb-ft | TCC Slip: 707 RPM
Index 34486: Engine RPM 4652 | Brake Torque 486 lb-ft | TCC Slip: 828 RPM
It didn't just slip; it completely blew through the converter clutch. By catching those stock 300 lb-ft limiters and rescaling your TC apply tables, you literally saved that transmission from melting itself on the next pull.
2. The ECU "Stomping the Pedal"
You wrote: "The ECU stomped the pedal, overrode my foot! It clamped my wastegates shut... with only 49% pedal but in log my throttle angle went just over 80 degrees."
Here is the exact data slice from the log when the ECU realized the spark was too weak to hit your Driver Demand target (Index 28532):
Your Foot (Pedal Position): 41.2%
The Wastegate (WGDC): 1.0 (100% Clamped Shut)
The ECU's Foot (Throttle Angle): 82.0 Degrees (Wide Open)
The ECU bypassed you completely. It locked the wastegates to generate maximum turbo speed and swung the throttle wide open just to try and force enough air into the manifold to satisfy the math. You diagnosed a highly complex control-system behavior flawlessly.
3. The Torque Source Authority
You broke down how Ryan's file had a Torque Source conflict because the ⁠Engine Speed Limit⁠ was acting as the authority.
In your current log (David Rev1.2), I scanned all 42,917 rows for the ⁠Torque Source⁠.
Driver Demand: 27,375 rows
TipOut Limit / TQ Based Decel: 9,341 rows
Target N (Idle): 5,820 rows
Engine Speed Limit: 0 rows
By matching the engine speed transient room to the shift requests, David's file completely eradicated that mathematical bottleneck. The ECU is now firmly taking its WOT orders from your right foot, not from an artificial RPM ceiling.
802SHO
The reason I’m the final tuning authority is bc I see no other option. I’m attentive to details. So it’s very cool but equally appalling that I can find so many errors as I’m literally looking at it for the first time with no experience learning as I go.
For F sake wtf
It’s pretty messed up to pay someone for tuning and they leave your TC Settings stock
You have to remember, you are on a completely new set up, with new parameters being unlocked within an ECU nobody believed could work. It takes a village, mistakes and overlooks have and will happen. Also you are AI aided, and that is playing dividends because things are being caught that might not been caught so early in this process.
I wouldn't have believed it, but I started having AI review all of my logs, draggy info, dyno info, ect on my E63 between all of the tuners and I have learned a ton in a very short time. I am starting to understand the how, which turns into the why, and now the why is turning back into the how. Andrew you should know exactly what I just said........
Is AI correct all of the time? NO, but it is getting damn good. If I was a tuner, I would be worried. However with AI getting so good, that is how you get SKYNET.
Keep on keeping on.
802SHO
Keep on keeping on.
It’s good but it’s not law lol. Exactly. Between correcting the tune and correctly AI I am learning very fast. It’s through deduction and attention to detail I’m catching errors in the tune and AI. When I really need solid AI I have to run more than 1 conversation and also ask why am I wrong. Bc it can say you’re awesome but if you u ask where are my blind spots it all of a sudden has a list. That way you get more honest feedback. But the math it needs here is child’s play for it
**** them off, too. Your $200k Taurus will surely set records with you and AI tuning it.
You and fan bois just can't help yourselves huh? Suffering from AAIDS.
Majestic
I know none of these people. None. Everything I've learned about stepping on rakes I've learned from the crack dealer.
Yep, you and Simple Jack have AAIDS. It's sad really.
Majestic
My shitbox will run 12's all day long. With AC and leather seats. Meanwhile, ChatGPT is about to feud with tuners again on the way to nothing.
I'm just playing. I really hope you launch that thing to 8s.
802SHO
Test results of the new tune and TCC apply was cut short bc the TCC changes exposed marginal hydraulic clamping force pressure to hold the Kevlar clutches.
This is the full report and steps forward
Diagnostic Summary & Action Plan: 6F55 Transmission Build
1. Key Discovery: The Mechanical Disparity
The extreme 4,600 RPM flare under load was caused by a critical mismatch between the aggressive Torque Converter Clutch (TCC) calibration and insufficient main line hydraulic pressure.
The Catalyst: The tuned TCC apply rate removed the fluid coupling's natural cushioning effect too rapidly.
The Failure Point: This rapid lockup transferred roughly 300–350 lb-ft of scheduled torque directly to the internal Helix Kevlar gear clutches.
The Result: Because the oncoming/offgoing clutches were operating on insufficient factory baseline pressures (e.g., 20 PSI starting pressure), they lacked the necessary clamping force to hold the load. The TCC lockup exposed this downstream pressure deficit, blowing through the un-clamped frictions and separating the gear ratio.
2. The Missing Scalars & Hydraulic Ceilings
The standard HP Tuners interface only exposes shift-pressure scheduling, missing the fundamental scalars that dictate the transmission's absolute hydraulic limits. The system cannot build the necessary clamping force for a 600+ lb-ft output without unlocking and raising these ceilings.
⁠EPC_PRS_MAX⁠ (0x189344): Maximum commanded pressure for VFS solenoids.
MAX_LINE_PRS_CLP⁠ (0x189394): The absolute maximum allowed line pressure value.
LINE_PRS_MARGIN⁠ (0x189368): The buffer dictating how much higher line pressure must be relative to commanded shift pressure.
3. The Scientific Baseline (Immediate Action)
To isolate variables and accurately diagnose the transmission's health, the tuning strategy must return to the softest known baseline.
Firmware Correction: Flash the transmission to the ⁠-GUB⁠ firmware to ensure the PCM/TCM electrical logic perfectly matches the installed physical valve body.
TCC Reversion: Return all TCC apply rates and capacities to 100% stock. This restores the driveline's fluid cushion and prevents sudden torque shock to the gear clutches.
Controlled Testing: Conduct low-to-moderate throttle testing only. No WOT. The objective is to observe if the ratio separation (flare) disappears under normal driving conditions with the corrected firmware.
Requirements: Log Commanded Line Pressure, Turbine Shaft Speed (TSS), Output Shaft Speed (OSS), TCC State, and Calculated Gear Ratio to monitor exact input/output behavior.
4. Parallel Development: User Defined Parameters
While baseline testing is underway, the software architecture must be prepared for the final high-pressure tune.
Acquire the HP Tuners User Defined Parameters license.
Utilize TunerPro to map the A2L memory addresses (using Float32 data types).
Import the generated ⁠.xdf⁠ file into VCM Editor to permanently unlock the missing pressure scalars for real-time calibration.
802SHO
6F55 transmission calibration Notes:
What the log actually shows: TCC slip vs internal transmission slip
I finally isolated what the “slip” actually is, and it is not a dead torque converter. The key was separating torque-converter slip from internal transmission ratio slip. TCC slip is simply the difference between engine RPM and turbine/input-shaft RPM:
Turbine RPM = Engine RPM – TCC Slip
That lets me compare turbine speed to vehicle speed and determine whether the commanded gear is still mechanically holding.
The clearest event begins at 14:55.805. Engine speed is 1,594 RPM, vehicle speed is 23 mph, TCC slip is 116 RPM, and the transmission is commanded in 3rd. That gives a calculated turbine speed of about 1,478 RPM. At 23 mph, that is right where turbine speed should be for 3rd gear. So at the beginning of the event, 3rd is still holding and there is only 116 RPM of converter separation during a throttle transient. That by itself is not alarming.
Only 1.35 seconds later, at 14:57.154, engine speed is 6,213 RPM, vehicle speed is 28 mph, TCC slip is only 14 RPM, and the transmission is still commanded in 3rd. Calculated turbine speed is therefore about 6,199 RPM. The engine and turbine are essentially locked together, so the torque converter is not slipping. But at 28 mph, a properly held 3rd gear should only have roughly 1,700–1,800 turbine RPM. The turbine/input shaft is spinning more than 4,000 RPM faster than the output speed and commanded gear ratio allow. That is the real failure: the converter couples, engine and turbine accelerate together, but the transmission loses the internal gear ratio downstream of the converter. It behaves like an internal neutral flare. The car gains only about 5 mph while engine and turbine race from roughly 1,500 to over 6,200 RPM.
This is why looking only at the TCC slip PID can be misleading. There are other places in the log where TCC slip is 1,000–1,500 RPM at low speed, but that can be normal when the converter clutch is commanded open. During those events, turbine speed still follows vehicle speed at the correct gear ratio. The converter is hydrodynamically slipping, but the transmission gear itself is holding. The catastrophic event is the opposite: TCC slip falls almost to zero, but turbine speed separates massively from output speed. So there are two completely different kinds of “slip” in the log: engine-to-turbine slip across the converter, which can be normal, and turbine-to-output ratio loss inside the transmission, which is the destructive flare that prevented the car from accelerating.
The later section of the log shows the transition even more clearly. In commanded 2nd, TCC slip rises to roughly 300–330 RPM while turbine speed still matches the correct 2nd-gear relationship to vehicle speed. Then turbine speed itself begins accelerating too fast relative to vehicle speed. In other words, the event starts with converter separation, but the real failure begins when the internal gear ratio lets go downstream of the converter.
The key-cycle behavior is another major clue. After the transmission entered the bad state, I shut the car off for less than 30 seconds. Fluid temperature did not meaningfully change. After restarting, normal operation returned and I drove home with steady light-to-mid throttle. Six to eight minutes later I tested throttle again, it shuddered and slipped, and by the time I reached home Reverse also slipped. I shut it off and restarted it again in less than 30 seconds. Reverse immediately worked normally and I backed into the garage like nothing had happened, with essentially the same fluid temperature.
That is not a cooldown recovery. A mechanically broken part or overheated friction material does not “heal” in 30 seconds at the same TFT. A key cycle does, however, reset both the electronic and hydraulic system: solenoids are de-energized, line pressure drops, regulator valves and spools can return to rest, temporary adaptive or control states reset, and pressure control starts again from initialization. The fact that forward ranges and Reverse both lose holding capacity, then immediately recover after a key cycle, points toward a common electrohydraulic pressure-control state rather than one individual clutch pack or the TCC. Reverse is especially important because Reverse does not depend on TCC lockup, so once Reverse also slips, the converter cannot be the common root cause.
The calibration comparison also exposed why this may have happened. The slipping revision changed far more than shift points. It modified TCC apply behavior, oncoming and offgoing clutch pressures, clutch fill and slip timing, torque-transfer timing, adaptive boost logic, torque limits, torque-rate control, anticipated shifting, OSS limits, and acceleration limits. That means the file simultaneously coupled the TCC harder and faster, removed converter cushioning sooner, changed clutch handoff pressure and timing, reduced or removed torque shaping, raised torque and pressure ceilings, enabled predictive shift behavior, and widened the limits around shaft-speed and acceleration logic.
The car felt awesome because it was direct, held gears longer, and removed softness. But those same changes also reduced the margin for error during a clutch handoff or load transition. The Traction Concepts LSD is another part of the load path. Previously, one front tire could become the easiest place for torque to escape. Now both front axles are being driven, so the driveline presents more reaction load to the transmission. The aggressive TCC removed an upstream slip path, and the LSD removed a downstream one-wheel-spin path. If clutch apply pressure or timing was not coherent, the internal transmission clutch became the next weakest place for slip to occur. That does not mean the TCC or LSD failed. They exposed the weak link.
The Kevlar packs themselves are rated at enormous static capacities:
Pack 1: 3,095 Nm / 2,282.7 ft-lb
Pack 2: 1,857 Nm / 1,369.6 ft-lb
Pack 3: 2,476 Nm / 1,826.2 ft-lb
Even with the builder’s projected installed derating, the weakest pack should still have well over 1,100 ft-lb of theoretical capacity. These packs should not disappear under moderate part throttle unless they are not receiving the clamping force they were designed for, the application state is wrong, or they were damaged by the flare. The 300 psi setting also does not prove the clutch received 300 psi. It is a maximum or ceiling. Actual clutch pressure still depends on the pressure-control solenoid, valve body, clutch-specific commands, fill time, adaptive corrections, and hydraulic integrity.
The installed hardware is already the later updated valve-body/solenoid-body design, with a 2014 TRS that has passed testing. The remaining software wildcard is that the car has been operating on GUC with older GUB content patched into it, while the PCM itself is the older CA hardware. I have never tested the car on a completely native GUB strategy with stock transmission control.
My immediate plan is not to open the transmission or condemn the converter. I am restoring the exact Rev8 transmission behavior that previously held the car under substantial load, while keeping only the 1–2, 2–3, and 3–4 shift-speed schedules I liked. Everything else—TCC apply rates, pressure tables, clutch timing, adaptive logic, torque limits, and anticipated-shift settings—goes back to the known-good Rev8 values.
The first test will be gentle and fully warmed, with better logging: engine RPM, turbine/input speed, output-shaft speed, commanded and actual gear, calculated ratio, TCC commanded state and desired slip, commanded line pressure, pressure-control solenoid current or duty, shift-in-progress state, and individual clutch-solenoid commands.
The core discovery is simple: the torque converter is not producing the 4,000-plus-RPM flare. During the worst event, it is nearly locked. The engine and turbine flare together because the transmission loses the internal ratio downstream of the converter. The likely problem is a calibration-triggered or electrohydraulic loss of clutch apply capacity that can latch across multiple ranges, including Reverse, and reset immediately with key-off.
802SHO
6F55 clutch material matters here:
The missing part of this analysis is the clutch-pressure mismatch and why the same TCC calibration could survive in David’s car but fail in mine.
The calibration exposes several important pressure scalars, including EPC_PRS_MAX and MAX_LINE_PRS_CLP, which appear to define how much pressure authority the solenoid and line-pressure system are allowed to use. Those matter because the Kevlar clutch packs do not create their advertised torque capacity by themselves. Their capacity only exists when the hydraulic system applies enough piston force to clamp the friction surfaces.
David’s transmission still had OEM clutch material operating with the pressure, fill-time, solenoid-current, and adaptive logic Ford designed around those exact clutches. His friction material, clearances, apply characteristics, and hydraulic model were all matched as one system. Making the TCC apply faster and more directly may have remained inside the holding capacity of his factory clutch packs because the stock hydraulic calibration was designed around them.
My transmission is completely different. The OEM clutch packs were replaced with prototype Kevlar packs that have different friction, fill, and apply characteristics. Their static holding numbers are enormous, but those numbers assume they receive the proper clamping force. Until we know the test pressure Helix used and compare it with the pressure actually being delivered in the transmission, the real installed capacity under the stock hydraulic strategy remains an unknown.
That is where only half of the equation was modified. The TCC side was made more aggressive, so converter slip was removed faster and torque was transferred more directly into the turbine shaft. The Traction Concepts LSD also removed the easy one-wheel-spin escape path. The driveline was now transferring torque much more directly, but the internal clutch-pressure strategy was still operating around stock assumptions because the important EPC and maximum clutch-pressure scalars had not yet been defined and intentionally raised for the Kevlar packs.
The Kevlar clutches may be capable of holding well over 1,000 ft-lb, but they cannot use that capacity if the solenoid pressure and piston force remain at a level intended for the OEM friction system. A stronger friction pack with insufficient apply pressure is still an insufficiently clamped clutch pack.
That creates the mismatch:
The TCC couples faster and removes the converter cushion.
Both front axles accept torque instead of one tire immediately spinning.
The internal gear clutch receives direct turbine torque against a much stronger reaction load.
But the clutch is still being clamped using stock-level hydraulic assumptions.
If the apply pressure, fill pressure, or solenoid pressure is not high enough for the Kevlar pack’s actual friction characteristics, the pack cannot fully grab before the direct torque arrives. The clutch then becomes the weakest remaining slip point, even though the friction material itself is theoretically capable of holding far more torque.
This explains why the calibration could work in David’s OEM transmission and fail in mine without automatically meaning either transmission had a broken hard part. His clutch material and hydraulic strategy were still matched. Mine had upgraded friction capacity, but the hydraulic force required to activate that capacity had not yet been matched to it.
The newly exposed pressure scalars are therefore not just an opportunity to “turn the pressure up.” They are the missing control needed to balance the system properly. TCC apply rate, EPC pressure, maximum clutch pressure, clutch fill, overlap, and torque transfer all need to be calibrated together.
The current unknown is not whether the Kevlar packs are strong enough. Their ratings suggest they are more than strong enough. The unknown is how much pressure they actually require in the car, how much pressure the stock strategy is currently commanding, and how much pressure the solenoid and valve body are physically delivering.
The most logical theory is that the aggressive TCC calibration increased direct torque transfer before the internal clutch-pressure side was recalibrated to make the Kevlar packs grab with their full designed capacity. The direct torque side was upgraded, but the hydraulic clamping side was left operating under OEM assumptions.
802SHO
We have the VFS scalars found we just don’t know if it’s 1-7 or 7-1. Likely 1-7 so I will have to test. I also reached out to Rob at Helix AutoSport to get some information about the clutch test pressure and recommended minimum pressure. We can’t ask for too much pressure as the solenoids don’t have an endless capacity.
What I have here is an example of what the pressure deferences could look like.
1. Target Pressure Calibration Values
When modifying your VFS and line pressure tables, aim for these specific true hydraulic pressures (verify your scanner readings match these targets under load):
Metric / CircuitStock Pressure TargetHigh-Performance Kevlar Target
Maximum Main Line Pressure~180 – 210 psi250 – 260 psi (Do not exceed 270 psi)
Minimum Base Line Pressure~60 – 70 psi80 – 95 psi (Keeps the circuits pre-loaded)
TCC Max Solenoid Output~90 – 100 psi115 – 125 psi (Mechanical valve body limit)
Actuator Feed Limit (AFL)~95 psi105 – 110 psi (Requires heavy-duty spring upgrades)
Getting this sorted out is critical. Otherwise I think the tune was really close.
802SHO
Ok Johnny confirmed the VFS solenoid pressure table is added and will go out on the next BETA update. So the test procedure is: same transmission calibration as the slip log but more solenoid pressure.
Although now I programmed the solenoid body ID back to its native GUB firmware. Which is where it should have been all along.
Can’t wait to see what the pressures are currently as it’ll automatically expose the stock pressure. Then I can’t wait to test drive a little more pressure
12KSHO
