Then the torque limit nanny isn’t your problem, is it? People are here giving you real suggestions but you keep lashing out for no reason since last October.
Lashing out for no reason? When was that? Sleeper isn’t right about fuel. It escapes me what you’re right about. It’s clear you are wholeheartedly GearHead. Other than that….
The torque limiters are my problem. We’re talking about HPTuners? The only helpful SCT tuner has been Brad (AJPTurbo). Sleeper didn’t help with his gap in understanding. Matt wasn’t helpful in fact his nonsense has the community thinking cams are the bottleneck. Oh and hey try some ULV bc..maybe it’s fluid and not my calibration? Or I’ll admit I’m not sure exactly where ULV originated from but what a horrible idea.
If lashing out was about methonal …that’s correcting misinformation but I guess you call that lashing out.
Uh so yeah very specifically torque limiters are my problem. Hence why HP engineering was requested. Which lo and behold there was an obvious limiter. Now the indicated engine torque tables were the limiter as I hit 1.92 load, torque source flipped to Ind.engine.tq limit the instant I was 1.90+.
What’s becoming clear is HP isn’t as defined as SCT however that’s currently changing. Again fuel definitions aren’t the limiting factor here. Sleepers “cut and dry” video is a masterclass in misinformation.
Maybe you don’t realize forum theory halts progression. By outsourcing thinking to the forum you’ll be stuck in old beliefs, beliefs that ppl are so emotionally attached to they’d argue against physics and engineering.
The main reason I’m actually continuing to improve is bc I test a lot and I take the results from objective reality and I use that to test better, smarter and solve problems. I’m not stuck to any one theory or belief.
I didn’t know how to do electrical diagnostics and most of what I did over the winter to get my car running good again bc I found the answers here. Normally I’d do YT or Google searches and instead I used an AI. Which turned out to help me a lot. Maybe bc I already knew a lot.
My belief system is reality. What I already know from my experience, plus what I’ve learned + what I found doing tests.
If I had listened to sleeper about what he said then HPtuners is off the table. Right? It’s untunable. Doesn’t have the fuel definitions and scalars needed to scale the XDI60hpfp and xdi2000cc injectors. Which didn’t survive contact with reality.
If I had listened to Sleeper or Matt I’d be stuck. Boxed in.
Instead I’m pushing 93 octane to absurdity data points. 1.92 load with PCM intervention and that’s not even an optimized air:fuel ratio. I’m actively a huge part of updating HPTuners 10-12 OS definitions working with both my tuner and HP Engineering, to the point the engineer is like a Teammate. He said this today, from Johnny P, “Well I know there is more in there. I have a lot ready to go but I’m slowly adding more to the definition. Just waiting on these limiters to get fixed.”
Sleeper and Matt look like roadblocks to me. And big ones.
