HotRodKid
mmmmm ... turbo
It's easy to check the clearance of the valves. Take off the intake and valve covers. Then with a good set of feeler gages. Just turn the cams (there's a big hex on each)
i would like to state, just so noone breaks anything, that you shouldnt try to rotate the cams using those hex heads if your timing belt is still on
if your timing belt is on, use the crank bolt to rotate the engine, using the hex's will take ALOT of work and youd be lucky if you didnt break a cam in the process
