97 sho cheap mods for the v8 anybody?..
turbot4
pa
so i was thinking of making a cold air open airbox, are there any gains too this and also .....
i keep seeing something about a y-pipe and removing rear cats...are the benifits too this?...
anybody have any input, thanks in advance..
turbot4
pa
so you saying it's not worth it too put in test pipes at the rear cats and don't make an intake?
You'll get throatier sound from the intake. I wouldn't do it unless I could do it on the real cheap. I have the third cat deleted and used to have a cone filter that sounded nice but got really dirty. No appreciable performance difference I can tell. I think with a good tune the car would wake up a little and take advantage of the changes, as well as firm up the mushy tranny shifts. Without a tuner I wouldn't bother. Just my opinion.
turbot4
pa
ok, thanks for the input...i guess i'll just leave it alone, no sense in messing with it anyway ....only problem i can tell, is sometimes the car just slightly is searching for an idle, and again not all the time, just once and a while....it has a new isc in it, so i don't know, but it has stalled on me 3 times since i started driving it....it goes and it comes, but makes no sense....the way it is acting is it's a bad isc...(idle speed controller) anyway who knows, i would like alittle louder exhaust, just so everybody knows it's a v8, so i may mess with the rear cats..
Mr Anonymous
Tire Wall
St. Louis, MO
Eliminating the main cats can make an improvement, but requires a re-tune to realize the gains. Even then, you're really only going to see about 5-10hp out of a tuner, and another 10hp out of a catless pipe.
Screwing around with the intake does absolutely nothing to add power, and can easily rob power.
Short of nitrous, there really aren't any "cheap" ways to make a lot of power with these cars.
turbot4
pa
thanks for the advice.....since it's my new dd i'm going to not mess with it....hopefully it will stay reliable for me....
bacernate
97 MONEY PIT
Denver, Colorado
I personally hate my cold air intake, very noisey and no power gains. It was on there when i bought the car.
Wire open the secondaries and get an xcal. Nothing else does anything unless you want to get into nitrous and serious trans mods.
turbot4
pa
ok, like i said not gonna mess with it now as i'm selling my super reliable gl which btw is mint with 88k....i can't seem to find a buyer for it even though i wanted 1500 obo...
so the sho will be my new dd....
so i'm gonna keep it stock other than maybe opening up the rear cats just for alittle rumble..
bad_4dr_sho
Now what broke
Dickson, TN
Flip Over Read Directions<---If only it was true. Damn:cool:
Hey I believe my Cold Air Intake, helped move my shift points a little higher.and it shifts a little harder. believe it or not. I've heard of a couple people who have noticed the same thing. That Goode's air intake. for 100. bucks I think is worth it. My Exhaust system I dont really believe it helped me make more power, I feel like it just moved the powerban up about 500 rpms. Which made the car a little sluggish launching from a light. Thats why I got the Torque conveter. I havent done the Cat delete yet. Good luck with your SHO.
turbot4
pa
cool , thanks....i mainly wante dto do it for some sound, as it is kind of quiet, i want people to know it's a v8, anyway as far as the intake....could you send me a link on where you got your, i may just make one, but i would prefer to have 1 ready to go...with the cold air wall and all..
wild01ride
Back in time...
Plymouth, MI
bad_4dr_sho
Now what broke
Dickson, TN
they sell the Goode intake ready to go on Shosource.com
Get the intake made for the car,Dont make one. The Goode intake has a heat shield and it actually works. I had a normal K&N filter that I had originally just put in place of the factory air box. And it sounded real good. But my gas mileage dropped by almost 3 miles per gallon. That was almost 40 miles less a tank. I couldnt figure out why. When I hooked up my scanner. I saw that with the car running it was taking in air around 114 degrees. I was losing performance. When I bought the goode intake with the heat shield. the air intake temperature dropped to the mid 80's. and I actually saw a gas milage increase over the stock intake. and it had great throaty sound. hopes this helps. goodluck with your SHO. Laterz
crystizel
