Adumb
TSN
a diesel engine redlines where our motors start making power, so the two are a little bit different.
So I walk back-over with her and the guy that serviced her car immediately gets defensive. "I already checked the drain plug and the oil filter is on there right." Okay - I replied fine and ask that they push the car back out. I check the drain plug and filter, look for leaks, then check the level - all fine.
Anyone want to guess what was wrong?
:blah: , first off i use RP in all my cars, always have and do all my own oil changes, 2nd i drive a 18 speed peterbuilt all day long so dont tell me i can shift, sorry i dont want to come flying into my driveway or rev it to 3k to creep over a curb , sometimes it happens, no big deal, rod bearings dont need to be changed because of it
The Low [ OIL ] pressure light illuminates when pressure at the sensor drops below 6 psi, if the Oil Pressure Sender is working correctly.
There is roughly a 7psi increase in oil pressure for every 1000 rpm increase in engine rpm. Conversely, oil pressure decreases as rpm decreases, and most Gen I/II SHOs will display a steady or flickering [ OIL ] light when the rpm drops to 500-to-600 rpm due to simple engine wear.
If you're allowing the rpms to drop below 800rpm while letting the clutch out, that's the problem as TopGunnYFZ indicated above.
A "bad" or weak oil pump is not likely. A malfunctioning Oil Pressure Sender is much more likely.
Do you know what kind of oil they use during the oil change? Using the wrong weight oil (eg. 5W-20) could suddenly cause you to get a Low [ OIL ] pressure light. Conversely, using a heavier weight oil can elevate oil pressure, which will prevent the flickering [ OIL ] light.
I'm going to play the contrarian here.
First, rod bearing damage like that shown in the image posted by 1993MTXSHO does not occur because seeing a flickering Low [ OIL ] pressure light once or even a few times. It is the result of poor maintenance practices - not changing the oil at regular intervals, running low on oil repeatedly or for extended periods, running the wrong weight oil, repeated burnouts and beating-the-shit out the engine, etc.
Rattle does *not* always mean a rod bearing knock. There are a number of other underhood problems that can produce very similar sounding noises, especially to someone that's not familiar with what a rod-knock sounds like. And even if it were a rod bearing knock, I know several SHO owners who have driven their SHO for months, beating the **** out of them before the engine let go. Ask SuperHO and St Louis SHO how long and how hard they drove their 3.0s before they blew.
First, if you're allowing the rpms to drop below idle-level (800 rpm) as you engage the clutch - stop it, use a little more pedal.
Second, put a mechanical oil pressure gauge on the engine and see what your oil pressure actually is.
Third, consider changing the Oil Pressure Sender - it's a single-wire sensor, inexpensive, and simple to change.
Fourth, I agree with Troywakeling - change your oil and filter to what ever weight and brand you were using before the last oil change. Also consider going to the next heavier weight in the interim.
Wanna hear a scary story why you should always do your own oil changes?
Several years ago, a female friend came into an O'Reilly's with that look on her face. I asked where her car was, and she said the oil light had come on and the Jiffy **** station told her the motor was bad (even though they had driven it in to service with no light on).
a diesel motor pulling 80,000lbs up and down hills and in and out of city traffic is much harder to drive then a 3000lb car with a 5speed no matter what the redline
i driven probley 30 different tractors myself... you let the clutch out without touching the throttle to take off... on a gas motor that is a no no..
get some revs up before taking off.
i hope to god you dont float your SHO
lugging the motor does in deed increase engine wear.
ever hear your valves tap like a bitch in a manual car when you damn near stall it?
still wanna say it dont hurt anything?
but i have to disagree with storm chaser... revving the **** out of the engine and all isnt gonna cause as much problems with your engine as lugging it.
i agree beating it does start to take its toll.
but simply look at sdpatts car.. he beats the shit out of it every weekend at the track.. granted he keeps up to par on his car but still hes got 366k miles on a car thats been beat since day 1
what kind of cost am i looking at to have the bearings done? this is not a job that i can handle and i would have to pay somebody to do it.
From RCM, 64.99 for all the parts needed to do the job unless you break off one of the exhaust studs. Being where the car came from I don't think you'll have that problem.
Do quit driving the car. Absolutely and without a doubt.
You're in Las Vegas now as I understand. There is bound to be someone in the SHO community over in that area that can help you.
And guys, quit beating him up for not taking this job on. If he doesn't think he's capable of doing it, it's best that he let someone do it for him perhaps while he watches and learns. Better that than getting in over his head and f'ing something up.
If your bearings were never changed, just change them for good measure. I herd no sounds in my 99k mile 93, and ran great, no light at all until i revved in my driveway when i got home and saw a little flicker when the revs dropped back tp idle but then it went away. I Figured ok that wasn't good but its prolly not to bad, so i pulled it apart the next day to change the bearings, and found this, the crank was screwed up and the engine was trash, at 99k miles. This was a meticulously maintained car as well, I mean the engine was so clean you could eat out of it, it had the 60k done at 60k as well, moral of the story, CHANGE YOUR ROD BEARINGS NO MATTER WHAT.
They didn't have 10W-30, so the tech used 5W-20 instead of calling one of the local parts stores to order a case of the correct weight oil.
That WAS the right oil...techs see a 24v taurus and assume it's a duratec. Happens all the time.
The guy I sold my car to called me up a week later and asked me why I sold him a car with no oil pressure. He even asked me if I used motor honey when he test drove it...I was just about to have a caniption when I realized he didn't change his own oil...
The tech used 5w20 because he thought it was the right stuff for a 24v ford.
