ultimatesho
got the setup finally done last night and all i can say is this new setup will take some gettin use to.........much much much better stopping not to mention they fill up ALOT more of the space inside the rim
The Brackets found on the Mark VIIIs are not FN74s, however they will still work.
Compare for yourself. The only difference is the extra nub.
[images deleted]
As far as bolts go, if you pull brackets off an '01+ leave the bolts, they're too long!!!
Hey, if you get the Cobra upgrade, you need to upgrade you rims?
And, with this upgrade. what upgrade is affective in the rear?
May be, and may be not.
Some have been able to run Cobra/Mach I calipers under slicers, and some have not been able with 17's. You can definitely run Cobras under slicers, if you restrict yourself to 10.9" rotors
Is it me, or does the brake dust make the Mark VIII brackets look a little "beefier" in the second and third images?
**********make sure you get the 4 caliper bracket mounting bolts (mount the caliper bracket to the spindle) if u have a 89-93!!!!!!!!!!*************
im unsure what cars have the right bolts i called the local FORD dealer and they told me the bolts were discontinued........i ended up telling a salvage yard i needed em from a 94+ TAURUS/SABLE or 95+ CONTINENTAL, so im not sure what ones i got...but they were to long so i ground them down a bit, and used a crush washer
old post says "12x1.75x35, grade 10.9 with integrated washer" is what is needed
Alrighty, just wondering... I have a '92 that I want to put the 96 brake upgrade on. Am I able to use a 96+ Taurus spindle or does it HAVE to be a 94/95?
********SPINDLE(KNUCKLE)/HUB ASSEMBLY********
94/95 TAURUS/SABLE/SHO with ABS
93/94 CONTINENTAL
